Can anyone help decode my engine please? I believe it to be a 230 ci or 250 ci. The number on the lower middle block are 2850817, GM 12 X is stamped on the lower middle of the block CON 2 at the back, H163 above the dipstick and F0829B is the serial # on the plate above the dipstick. The head casting is 4435F18 on the front passenger, 7880 in the middle and 8062 on the drivers side behind the manifold. Many thanks.
'67 4 door, 65 wagon. WISCONSIN
F0829B = Flint, built Aug 29th. Not sure on the B, most Nova codes are two letters and depend on the year of the engine. More info here, http://novaresource.org/codes.htm
The casting number you gave (2850817) doesn't exist. It's probably 3850817 which is a 1962-78 230/250 block.
Casting date (H163):
H = month; August
16 = day; 16th
3 = year; 1963
Assembly code (F0829B):
F = assembly plant; Flint Mi
0829 = assembly date; August 29th
B = application code; 230 with Powerglide from a 1963 full sized Chevy
