Last one that I worked on, I loosen it with my hand...by moving switch behind it and turning it ( as in the bezel )
Made my own. I used a piece of scrap and turned it in the lathe. Drilled and inserted two spring dowels on the one end.
tool
i made my own too. i took an old lugnut and ground down two sides where there would b like a screwdriver ridge in the middle. worked just fine
Banned
i used a Ford spark plug non-fouler, set it up in my drill press, drilled two holes, drove in 2 roll pins and wha-la. :D
easy-peasy-japaneasy! :D
the one i bought, the pins were a tad too wide to work properly...
I usually stick a snap-ring pliers in the slots and fumble around dropping them constantly while scratching the living sh*t outta everything..........:yes::D
