I recently poseted on weather or not to get this dana 60 for 400 or a ford 9 for 100. I just found out that the dana has a 23 spline axles. I didn't know they came that way. Whats up with that????
Seeing as its only a 23 spine is my 8.2 stronger as it has 27. And is that dana worth anything to get???
What is it going in? How wide is it? blah blah.... 23 splines axles must be massive. I was going to buy one (Dana)for $200 and decided that I can make my 8.5 10 bolt strong enough to handle 500 HP on the street. Personally, I would not hit a dead horse in the a** with a 9 inch either. They use gobs of power to turn, the pinion is at a stupid angle, it has different length axles, the pinion supports never hold up long unless you buy the high dollar case. The one and ONLY advantage I have ever seen is the set up. If you must have that option look for a early Olds or Pontiac rear.
Why not a 12 bolt? You can make them just as strong as a 9 inch for less money. They are easy enough to narrow, just whack the ends and buy bolt on bearing ends for them. I ran one for 9 years in my Drag car with a 4 speed and a 65 pound flywheel doing 7000 rpm launches and only replaced one (1) ring and pinion in that 9 years. I had Mark Williams axles, but they are cheap anymore. A Dana is just a gignatic 12 bolt. All the strength is in that case. You would bend everything else before you shucked a pinion out of it. Like I have seen too many 9 inch fords do.
To answer your question, it would not be worth the expense for a street/strip car. Dana's are meant for heavy cars with Ultra high horse power engines. One advantage they have over all the others is you can get a 7.17 ring and pinion ratio for it.Do a search of Chevy HI-performance where they were covering the 8.5 10 bolts in two turbo drag cars running in the 8's. Good enough in my book.
the dana i have is a 67 hemi rear it has 23 splined axles with one of those lockers . it came out of a car making 600 hp and big slicks with a 4 spd., it is all stock he never broke it . i havent either.
i would trust it no matter what . very common in older hemi and 440 cars.
Do Dana 60s really use up alot of power?
When I had my wrangler I used to pound on the Dana 35 all day and night going through mud pits, climbing rocks, and blowing through the deep snow we get here in NJ sometimes. I busted the transfer case and the driveshaft u-joints a couple times but that rear always held up. Of course it was the 6 cylinder HO but it was torquey as hell.
It would be great if someone did a right up on this.
no more than any other rear. the 9 just has a odd pinion gear contact and it uses a little bit more to turn. nothing you would notice . to me the diofference is the deflection or lack there off. with a dana in the housing , big beefy tubes mean no warping. unlike a factory 9 inch housing.
oh buy the way the 8 inches can look like a 9 , the bottom 2 bolts on a 9 carrier can only be tightened with a wrench. if you can put a socket on them its a 8 inch. and 8's and 9's can use the same axles. there is no difference
and be carefull not to get one of those 78 lincoln 9 inch rears they are junk. i dont think they are true 9. something like 9 1/4 jbimmolate would know better.
