After moving the springs inbord with the Comp Engineering kit. My shackles are all messed up. What is the easiest way to solve this issue? I was thinking of cutting the mount off the bracket and re-welding it where it lines up better with the leaf eye.. The spring perch measurements were taken with no weight on the car, and then welded, centered on the housing. The spacers that are in the pics were from the original owner of the car.. Not sure what they are for.. Should I bolt the tires on the car and see if everything settles? The shackle on the left side is the worst (as you can see) The lower bolt is actually pointing downhill quite a bit. The bushings do not have that steel rod going thru them.. Is that needed??
