Ok I have done a search on this everywhere and couldnt find any info.I am putting a 427 big block with a super T-10 in my 69 Nova. I have origonal GM big block frame perches and correct motor mounts,engine is in and fits great. Origonally it had a 6 banger with the powerglide 250 I think it is trans.If I have this right I read on here you can use a turbo 350 crossmember and slot it an inch or so to the passengers side so it coincides with the engine location.Well I found a website and it stated the dimensions and location of the trans mount on a powerglide 250 are the same as a Turbo 350 trans and it appeared the crossmember was the same. So my question is can I use my powerglide 250 crossmember and slot the holes,anyone ever done it....Thankyou in adavance....Dave
I'm not sure about the auto crossmembers, but I do no a 4 speed one can be redrilled. I believe the height is different from auto to manual crossmembers. I bought an aftermarket BB Camaro one that fits fine.
Cool,I'm going to pull the crossmember today so I'll check it out,I dont mind redrilling it if thats all it takes thats easy.
