It ran perfectly fine before I started messing with the timing. I read the Distributor install in Best of Drivetrain on how to set timing and I felt I had to start over even though my engine was running. I took it for a road test and it fell on its face. Instead of adjusting my carb, I figured I set my timing right first.
These are the things I had set wrong or didnt do right initially.
1.) using ported vacuum
2.) didnt remove the springs inside distributor while checking advance curve
3.) didnt measure my balancer and / by 10 to get 36*
4.) my buddy just sold me a tach so I felt I needed to know what RPM the curve was in.
My tranny was out of adjustment and leaking so I put some dexron III ( its overfilled now ) I didnt have time to drain the extra out. But could I be getting tranny fluid in my vacuum modulator and into the carb?
The carb was sputting out some nasty black smog that lingered around for a while. It landed on the engine area and it wasnt evaporating so I figured it was oil of some sort.
Lastly, I checked the timing with my light while it was running right before I took out the distributor and it was idling at around 50 degrees on PORTED vacuum ( guestimate after measuring where 36 degrees was, it was almost double the distance) BTDC
The first thing I did was set the HB to TDC ( used a rag in plug hole ) and remove the cap and verify the rotor position and it was about 3 terminals off......But it was running. I tried gas in the carb, and the best I get is a nasty, sputtery poof.
Should I just play with timing to get it to crank? My battery is dying so I had to quit. Ill try and get a video
