For those that have this setup, what hoses are you using? I have a 67 SS with fenderwell headers, so there is quite a bit of open space to run the lines. The kit CPP sells (6267HK) seems to be 45 degree fittings. That may work on the pump side but the box side would probably be best with 90 degree. Also, my pump would be a female fitting for the PSI side and most kits seem to be male. Do I just have them custom made and call it a day? Curious what others have done. Thanks in advance.
