I'm going to be putting power steering on our 67 Nova soon. Given there are only 2 choices for power steering boxes, which would you choose and why?
Has anyone gone from Borgeson to CPP, or started with CPP and went to Borgeson?
I've read of some failures or poorly manufactured CPP boxes but have read very little feedback on the Borgeson units.
I can the get the Borgeson box local for about $70 MORE than the CPP.
Anyone?
I have talked to you about that option. it's out of my price range.
I will be calling you soon about the sub frame connectors I got from you a week ago. I have an idea I want to run by you.
Are you keeping the stock column? I'm running an ididit and tried the Borgeson, but found they are incompatible with each other. I had to go with the cpp unit.
I was going to replace the stock column with a tilt one. Looks like Borgeson is the only one making that adapter for 11/16"-36 X 1" DD. But it does exist.
So I have power steering and the wheel is very sloppy. If I replace the gear box to a close ratio will it be better? Is so link to the box I should buy?
