cpp front disc brake conversion brake line
help,did the cpp deluxe sub frame conversion on my 63 no problem,just installed the zero offset front disc brakes no problem,now installing brake booster/dual master cylinder with prop valve and can't figure out how the brake line for the rear brakes goes,the kit from cpp has the plug to isolate front brakes and coupler for rear brakes,the line shape looks almost the same as the front brake line but they say it goes under the engine along the crossmember,to me it seems too long,thanks,oilman hope someone out there has done this,not sure to install top side or from underneath
