1 - 3 of 3 Posts
#1) I have a 750 double pumper but the center section has been replaced with a Proform center section and I don't know the exact model carb I have. The metering blocks have #'s on them but none of them match up with Holley's carb models I've found. Is there any other way to find out? What are the usual 750 DP #'s? I want to get a rebuild kit
#2) How do I tell what cc my accelerator pump is? Mine is leaking and I'm assuming it causing my low end stumble I have. Will it say something on the diaphram? 30,50?
#3) My power valve has a 4 5 6 stamped on it. Does this mean I have a 4.5 in Hg?
Sorry for the entry level ?'s but I gotta start somewhere. Thanks guys
#1) I have a 750 double pumper but the center section has been replaced with a Proform center section and I don't know the exact model carb I have. The metering blocks have #'s on them but none of them match up with Holley's carb models I've found. Is there any other way to find out? What are the usual 750 DP #'s? I want to get a rebuild kit.
You want a rebuild kit for a 4150 model. 4160's are Vacuum secondaries.
^^^ The 50cc pump is thicker (attached) and the 30cc pump is thinner (below)
Yes.
1 - 3 of 3 Posts
