Ok, I'm not sure what approach to take on this.
I installed the studs with ARP thread sealer (teflon white paste) as suggested by ARP. Only to find a majority of the studs on drivers side and maybe one or two on passenger side are leaking up into the valve covers and also some of the shorter studs under the headers. I found this after breaking in the cam, I re-installed the inner valve springs and found the coolant in the low areas of the heads. Also, slight milky color in the oil. No coolant in the cylinders.
A search has found that some have used a coolant sealer and others red rtv sealant.
Do I use a can of the coolant sealer and try to seal it.
Or
Can I pull one stud at a time, leaving the heads and intake (with blower) installed, and use the red rtv sealant.
Or
Pull heads, manifold, etc, and chase head threads clean then use red rtv.
Any other options I might have missed?
Thanks for your help,
Or
Or
