I have always wondered why the front suspension upgrade for the first and second gen Novas were called the Mustang II. I believe the Mustangs were downsized and called Mustang II in 1974. The original Nova suspension looked almost like a Macpherson strut. The Mac strut is a widely used modern front suspension. I think it started in the mid eighties, or maybe when front wheel drive cars appeared. So, as most modern cars are using the Mac strut, why was something like that not designed for the early Nova's?
I searched for a picture of what the actual front suspension on a Mustang II looked like. I mostly got the retrofit version made by various companies. I sorta found one though. The M II suspension is basically a suspension with a pair of frame rails with a crossmember under the engine. Each side has an upper and lower control arm with ball joints supporting a spindle. There is a spring inboard of the spindle running from the lca to the frame, with a shock running through the spring.
I have mostly had GM cars in the 70's. The basic description above is what these cars were equipped with. With our Novas being GM why was the a-arm suspension called an Mustang II and not say an X, F or G body suspension or simply A-arm suspension?
Various companies are upping the engineering on the MII suspension and saying it is a new design and no longer called an MII. However, when you look beyond the fancy engineering upgrade, they are still two frame rails, with a crossmember under the engine, an upper and lower control arm with ball joints supporting a spindle and a spring and shock (coil overs, but still a spring and shock) from the lca to the frame.
