1 - 17 of 17 Posts
Tried in another section with no response. What would cause the floor shifter in a '69 to not move even with no linkage hooked -up?
The spring under the horseshoe handle tab is either broke or seized.:yes:
If you look at your earlier first post in drivetrain and performance, you will see that 72Orange replied with his post saying same thing and has a picture of the shift tab.
Gary
Thanks guys. What is the availability of replacement parts? Will any from another year interchange?
If I'm not mistaken, I have a solid shift rod that goes from the TH400 shifter to the shift lever on the floor?
You have a shaft inside the bent shifter handle. If the plastic button at the top of the shifter is not springing up the lock is preventing you from moving the shifter.
1 - 17 of 17 Posts
