so does the shifter mount in a different location more to the center, or is the shifter arm bent to be more centered?.. and the shifter will need to sit more to the center, so you will also need to use the correct shifter.
The shifters both mount the in same place with the same mounting kit, from Hurst, but the actual shifters are in a different position. This link has a pic of a console style shifter and you'll notice it comes up to the center. Post #24so does the shifter mount in a different location more to the center, or is the shifter arm bent to be more centered?
