I'm considering building a high rpm race motor out of this nice old small journal 1967 327 . I've got some ideas that I'll lay out here and I'd like some good solid constructive advice/ criticism from guys that are more knowledgable than myself. I'll lay out what my idea is below and then whoever wants to....go ahead and let me hear it / have it lol
I'm currently building a 385 torky for street use that wont see more than about quarter after 6 that's gonna go in my 66 chevelle this spring .
But on with the 327 plan/idea .
This piece of history has been layin on the floor since 03 when I traded an 83 350 882 headed mexican block s h itster for it lol
It's been begging me ever since .
Im thinking maybe build this thing to twist 8300 rpm max 450 to 500 power at about 8 grand with a very long duration high lift cam and run a 456 gear with a stout th350. 13 to 1 or more CR
First off I'm thinking I need to build as much torque as I can because of the smaller inches.
How to do that is the big question along with the small cubes lol
So now I dont think I can put a 350 crank in this block seeing as it's small journal but correct me if I'm wrong .
I'm going to assume for the moment that I cant . So if that's the case I guess I'd be better to use the 327 crank that's in the block now for more torque versus putting a 283 crank in it and destroke it to a 302 . If I did the latter I could spin it to the moon but is there a way I can get more torque that way ??
Longer rods ?? Idk .
OR might I be better off with the 327 crank ?? And if that's the case the question of building torque still begs .
And how much can I would I should I bore this block given the stated goal ?
Then for up top maybe a small cc runner head ?? 180cc or less ??
Then I thought I'd run a true dual plane without a cut out in the divider with quite a bit of carb on top and maybe an anular booster. The smaller heads and the dual plane intake ought to help out with the torque I'm thinking but again I'm wide open for any suggestions or critique. I'll take anything you got other than " start with bigger inches "
Because this is what I got and it's a 67 and it's cool and I want to build it and thats my story and I'm stickin to it lol
