We did a compression check & found the readings on our 383 stroker to be 165, 180, 180, 175, 170, 195, 170, & 190. Are these variations normal, or is there an issue somewhere?
A little variation there but I wouldn't worry about it too much unless you are having an issue. 10 percent variation is normal. You're close to that. You did the test with the motor warm? How many miles on the engine? You could always run another test to compare the first numbers against.
I use a compression check for 2 things, to see what cranking compression based on the cam specs to see how its doing and for gross failure. Your engine looks fine.
