Let's dig up a REALLY old thread.
Ok, I got the wheel, button, and hub. The hub's too small, in both height and diameter. I got a 64-65 corvette wheel hub, on someone's recommendation. Should I just get the 69 Nova wood wheel hub instead?
I just installed this very wheel in my 66. There is specific hub that will work with that wheel the same hub that will adapt the factory wood wheel to the steering column and will also cancel your turn signal. I bought mine through Year-One along with the canceling cam for the turn signal. It also comes in a kit which gives you the horn button as well. All of this will set you back a Franklin but be careful not all years are the same the 66 and 67 are different I am not sure about 65-66. Good luck I really like that wheel it is very comfortable.
PM sent.....I just installed this very wheel in my 66. There is specific hub that will work with that wheel the same hub that will adapt the factory wood wheel to the steering column and will also cancel your turn signal. I bought mine through Year-One along with the canceling cam for the turn signal. It also comes in a kit which gives you the horn button as well. All of this will set you back a Franklin but be careful not all years are the same the 66 and 67 are different I am not sure about 65-66. Good luck I really like that wheel it is very comfortable.
Hope the information I sent you last night was good enough to find the parts you needed at www.396.com.PM sent.....
There are a couple of possibilities I'm looking at, and I should know within a week or so.Glad you brought this up again Greg, I'll be trying to do the same soon.
I have an Olds sport wheel and the hub I have is too short as well.
Let us know which hub fits a 1st gen column with the wood or sport steering wheel.
