I rewired my 65 with the AAW kit now I have no spark and if I leave the key on it burns up the HEI coil. I have an MSD 6AL hooked up and have tested it and it appears to be not working properly. Could the MSD be causing the coils to be catching fire?
I suspected that and went through and cleaned all the grounds I'll go through them again.
I called AAW and think I have found the problem. I have pluged the pink ignition wire into the distributor and have the small red wire from the MSD pigtailed onto it as well. I have to unplug it from the distrubutor and only have it pluged into the MSD. I am ovrepowering the unit.
