Im sorry, but I cant tell where your shocks were mounted on the axle.
But yeah, keep the leaf springs but mount the shocks as far outboard on the axle as you can, dunno if you can get a mount on the outside of the leaf spring perch, kinda looks like you can. If not then they need to go inboard of the spring mounts. 45 degrees sounds like alot of kant for a shock, Im not sure, QA1 could solve that problem, give them a call. And QA1 shocks are great for your car, they are quality pieces..
I had a similar issue, my rear was setup for straight line track, 1/4 mile. The shocks were way too far inboard for street driving.
So I moved them way out, after I had my final wheel placement. I dont remember what the actual degree of angle is off the top of my head. But I called the shock manufacture to make sure it was within their specs and it was.
Some pics. Before and after. See they were straight up and down and very far from the wheel, not a good street car suspension. So I moved the lower mounts out to the wheel where they can do their work.. JR
See the shocks were close together, not enough leverage going on, for the street.
And now they are acting on the outer most section of the axle tube, better leverage, more control.
