1 - 3 of 3 Posts
Does anyone have a diagram or pic of the clutch fork return spring and rod set-up on a '68? I can't find where the spring attaches to, and also the rod that attaches the spring to the clutch fork doesn't want to fit without interference from the left header :confused:
Thanks,
Darrell
Darrell,
On sb cars that rod has to go to the front cross member of the subframe their is a hole drilled for that rod if it was a manual shift car from the factory. But since you have headers not stock manifolds the headers will be in the way. What I did on my last small block car is I made a bracket. It attached some were around the motor mount on the block bent down so I didn't need to use that rod just the spring. hope this helps!
Jason
Okay, thanks. I will look into fabricating a bracket also.
Darrell
1 - 3 of 3 Posts
