I have a m21 behind a small block. It started of with a centerforce clutch and a stock flywheel... after side stepping the clutch more than a few times :devil:, i noticed the clutch wouldn't fully disengage. thought it was the clutch going out, and replaced it with a zoom 3 finger clutch. bad choice. put everything back together and after a few days of driving, had the same problem, along with BAD clutch chatter. at the end of the day on my way home, the zbar snapped and the pedal stuck to the floor. mad it home by leaving it in 2nd and using the starter to take off. bad, but hey, it got me home.
after this, i decided the clutch was too stiff, and a buddy implied that maybe the stiff clutch put more stress on the linkage and z bar, causing it to break. i ordered a stock-style diaphragm clutch from zoom, along with a new z bar from classic industries, and a Hayes lightweight steel flywheel. after everything was installed, the clutch was nice and easy, but there was still a minor amount of clutch chatter!! The car shifted fine for a week (with me ignoring the infuriating sound of the clutch chatter), and now I have the same problem off and on!! one day it will shift fine, and the next its hard to shift, grinds into every gear, so i know its the clutch not fully disengaging.
Any ideas? everything in the clutch/tranny department is brand new. shifter, rebuilt tranny, flywheel, clutch throwout bearing, pilot bearing, linkage, z bar, all new.
the z bar mount on the frame side is somewhat bent, but still allows the z bar to move unhindered, and i dont think the minor change in geometry would make such a huge difference?
do i need a new z bar frame mount?
could the motor mounts be affecting the linkage geometry?
why is the problem off and on? is it temperature related?
im somewhat lost, the best thing i can come up with is to check the motor mounts, and either make or buy a new frame side z bar mount?
any help is greatly appreciated!!
