I’m having trouble finding the proper clutch fork for my setup. We have checked several, they bind against the release bearing thus destroying it. What is the correct fork part number?
I have a 403 bell housing and 10.5 clutch, flywheel etc. with a T5 transmission.
Richard --- I used what was already mounted in my '403' bell.
here are some pictures ; if that will help. I did remove my 'clutch fork' and looked for a number , I did NOT see one. My clutch is working good (for over a year, now. 1st drive ; March 17, 2018.
Pictures :
#1 --
#2 --
#3 --
#4 --
#5 --
#6 -- This was when I was going with my "Saginaw 4 speed" ------
the 'fork' was already with my bell .
#7 --' 403 ' bell as used on my '250 - 6 with my T 5 trans (with no adapter plate ----- bolted onto the 403 , just like my 'Saginaw' .
I think that I have a New Clutch FORK , that I bought from
… "Chevy - 2 - only" --- when I bought all my pedals and clutch linkage. If I remember right -- I Did put the 2 forks side - by - side, and compared them. BUT -- I did - not - take any picture. The (my) new fork is in the shop , I can look at it tomorrow ------- it may have on "part NUMBER ON IT" .
All My pedals & linkage (z-bar , & rods are stock parts -- to fit a 69 Nova) .
just trying too help out ----- jim
Thanks! I did find the gm part numbers for the 403 and ordered the matching set off Amazon of all places!
Fork gm # 3892632
Bearing gm # 19245400
so, I go to the shop; I found the box that my new 'clutch bellhousing fork' came in (no fork inside of box). Maybe I did use that new fork ----- because, I did find my two 'old forks'. I compared those --- they are Very Close --- I did take some pictures , side - by - side …… only real difference was one fork is about an inch longer -- on the very outer - end … (I wouldn't think that would matter ? ? ).
The Part Number on the BOX -- 18009 (came in a change-over-kit … from Chevy-2-only -- that may be their Part Number).
there was another # on the box also : " W-692 … 67 - 72 'clutch fork " .
FYI : just looked in the newest 'Classic Industries' catalog , page - 542.
(I used the stock --- short throw-out bearing , with my set-up).
glad too hear you have it covered ……. jim
