Alright, I have the choice between a 12" clutch and pressure plate setup and a 11.5" pressure plate and clutch, they are both in my possession and both are used, but still good enough to install on my nova.
I am running a Saginaw transmission with a truck bellhousing, (the front bearing retainer was swapped on the transmission for one from a 3 speed truck Saginaw because of the different sized holes)
So... which one should I run? BTW the 12" clutch came with the flywheel I plan to use. Unless otherwise convinced, I have no intention to turn the flywheel...
Robert out!
Robert out!
