Hopefully someone can give me a hand on what this may be. I have a 1974 Nova Hatchback with a 3:73 posi rear. When I put the car in drive and reverse everything is fine. Once I drive the car for about 10 minutes or so and begin to slow to speeds of 15 mph and below I get a loud "clunking" sound and jerking coming from the rear. Driving at speeds greater than 15 I am fine. I replaced both the front and rear u joints, inspected the brakes, put the posi additive and lube in rear. Any advice would greatly be appediated
Sent from my iPad using AG Free
Sounds like you don't have the right rear gear oil, or the right amount of friction modifier in it. You're more than likely hearing the clutches popping and grabbing after it gets warm.
If you're running the stock Eaton posi unit, you can not run synthetic oil, period. I had a long telephone conversation with the owner/chemist at Redline. He convinced me that I could. 1 year later, I had to rebuild my posi. Don't risk it. Use the factory GM oil and the GM modifier.
Get ahold of Miles (jbimmolate) and confirm.
Chuck
1963 wagon
ok First are both rear tire the same size, brand & tread life? Next did you use synthetic gear oil or standard? Third what type of additive did you use?
Miles
Discussion Starter · #5 ·
First off thanks for the quick responses..I put 75w90 gear oil..synthetic blend..Transx posi additive..tires are both the same size and have same tread life
1963 wagon
Synthetics do not mix well with additives and most posi manufacturers say to not use synthetic fluids since it shortens the life span of the posi unit. I would go with a good 80-90wt oil and use either ford or GM additve.
Miles
