My car is a 72 Ventura with a 400 ci chevy, 200 4r trans and a 4.10 posi and I have two problems I cannot figure out.
#1 - The car vibrates on the highway. I believe it is coming from the front end since the steering wheel moves pretty bad. The vibration seems to occur from 50-85 and may even continue on up so it doesn't seem like a tire problem since it doesn't really smooth out. Since I bought the car I have changed the front wheels/tires, balanced the driveshaft, changed the front springs and the vibration stays the same. Could it be the alignment? The wheel bearins seem good. The car does have front drum brakes - could the drums be unbalanced? Any ideas??
#2 - There is a 'clunk' from the rear end when backing up, turning and goving over a small bump. It happens every time I leave my driveway (I back out). Even if I am going very slowly there is a loud clunk from the drivers side rear tire. I have made sure everything is tight and it is. The rearend is new and so I think it has something to do with that. It 'almost' seems like the diff isn't slipping correctly - but I would think that I would notice that in regular driving too.
Any help/ideas would be greatly appreciated.
