same
Just giving you an update on my 275's/28's under my 64 Nova. The MT Sportsmans were put on my 7 inch Weld Wheels. With a 1/2 cut off the front of the wheel well fender and tapping the wheel well fender nubs in ( I did find a bit of body filler when doing this and will have to do a small fender body repair), I go them in. Interesting that on the passenger side of my fender, I have a larger clearnance than the driver's side. I am grinding down the inside fender mound ( about 1 inch up from the opening) to allow more clearance only on the driver's side. I can actually drive it when I raise the car an inch or so with my air's, but still proceeding with the grind. Again, these are MT's Sportsmans Street Radials, have a 10.3 section width and about 9 inch tread width. Has that 28" height which really looks solid on the early Nova's. Will keep you posted on any new developments.
