What is the best way to clean stripper off your sheet metal? I was thinking of using a plastic spatula to get the thick stuff off and using a rag with hot soapy water to clean the rest. Will this work ok? Any other ideas? Thanks Jerry.
Nah, only when I'm onlineTY70SS said:You beat me to it drivewfo.I was going to say something like that. You must stay on here all the time.
On a serious note, the stripper if it good stuff will eat a plastic spatula up, you need a metal putty knife or scrapper to get most of the paint off. Follow it up with coarse steel wool or scotch brite pads. wear rubber gloves and use eye protection, Have fun, its a messy job.elkenova said:What is the best way to clean stripper off your sheet metal? I was thinking of using a plastic spatula to get the thick stuff off and using a rag with hot soapy water to clean the rest. Will this work ok? Any other ideas? Thanks Jerry.
Ummm...I've never used a bondo spreader on a stripper before....can you tell more how this works?!?!Toms73NovaSS said:I have had very good results with using a bondo spreader. I was using aircraft stripper and it did not eat the spreader....
Yup, we don't believe in any boundarys, though I must say I've never eaten the spreader after using it on the stripperToms73NovaSS said:So I guess it is true what they say about the Amish life style and sexual deviance........
It's best not to run one over with your car to begin with. They're much less likely to perform for you if they're splattered all over your sheetmetal.elkenova said:What is the best way to clean stripper off your sheet metal?
What he said.novanutcase said:Elke,
Doing the same thing as we speak. I've found that first use aircraft stripper. Buy a 2" wide metal scraper and a 2" wide plastic scraper. I use the metal scraper to get all the old bondo off and the plastic one for general use. It'll take many attempts since the stripper doesn't penetrate well through the bondo. I've found the best way to deal with it is to lay the stripper on the bondo and cover the area with some plastic film, this way the stripper doesn't dry up!(I can already hear the jokes coming so be prepared!) Make sure you let the stripper sit for at least 15 to 30 minutes so that it penetrates the bondo then scrape like a madman! Oh yeah, steel wool is good to get all the little stuff off but be careful because it loads up pretty quickly and you'll go through a lot of it if you don't try and get as much off with the scraper. One other thing, to keep the mess to a minimum I've found that you can use a small cardboard box to wipe off the paint sludge that develops on your scraper as your working. You just wipe the scraper on the edge of the box and it falls into the box. Good Luck and post some pics of your progress. I'm going to post some progress pics this weekend!
