Hello all. I have a 66 with all Church Boys racing suspension up front. The entire front kit plus the upper control arms, coil over conversion kit along with their billet spindles. All super quality stuff I might add. I also purchased the Wilwood brake kit SLC56 from them. That is where my issue is happening. I did a test fit this past weekend and noticed that the rotors are rubbing on the nuts that connect the steering arms to the spindles. Does anyone have this similar setup and did you experience the same issue?
Any suggestions are appreciated
Thanks for the reply. I have called twice, left voicemails, and sent an email via their webpage. Unfortunately, I haven’t heard back from anyone.
Got a call from Church boys and was given a solution to my problem. I haven’t tried it yet but I think it will work based on what I see. Sometimes the obvious is the most difficult to see. Just flipping how the bolts and nuts are attached to the spindles should do the trick!
