My 68 Chevy II, with 250 inline 6, is factory rated at 155 HP.
I think the Mercruise (boat) is basically the same engine, but rated at 165 HP.
How does the Mercruise gain an addditional 10 HP over the Chevy engine?
Just a guess on my part.
I would guess that the cam has slightly different duration and lift. Most boats with that motor would assume that they will run at a constant rpm, usually in the mid to high 3k range.
My other thought is that the exhaust is a bit more free flowing than a car system.
Doesn't take much to get 10 hp.
Cam and exhaust Are different then that of a car . But the exhaust alone would make that much difference If not more so.
I have the Langdon cast headers on my car, so I probably picked up a few HP myself.
Guess I could check out the cam spec's to see the difference between the two.
Agree with the cam & Exhaust
But...don't think that putting that merc cam in a driver is a good idea, because it isn't. Merc and the aftermarket suppliers are real proud of their parts. The engines need a totally different power curve and have vastly different stresses. A boat engine operates a constant speed and constant load. Think dragster engine. If you are looking for more power, get with your local speed shop, machine shop or the folks at Summit/Jegs/etc to develop a total engine system.
Tom Langdon sells alot of those merc. cams for use in daily drivers. And nobody that I know of has not had any issues with useing it.
