looks great... not to bag but constructive criticism OK ? i can't tell gauge line up in the images.
just my thoughts... the gauge's bezel outer diameter is almost perfect with the diameter of the instrument cluster, but it's slightly offset. if the material removed from the cluster was even, the gauges are offset slightly towards the center and the outer area of the cluster will then not match up with the gauge.
slight material removal towards the outside of the cluster and it'd permit the gauges to be installed as if they were meant to be there and not just fit into the cluster... if that makes sense.
not baggin' on ya but speaking to bring it to your attention... like i said, i can't tell from your images what the cluster to gauge alignment is
this was taken prior to completion to show slight offset, mine now fit even in the holes.
{quote taken from cluster mods album} the guage bezels edge needs to match the ring on the stocker bezel. constant test fitting will ensure a proper matchup of these units. take your time and grind accordingly to center the gauge to match the edges.
don't get me wrong, what you're doin' is great :thumbsup:
you know of course that the two 5" gauges need to be installed AFTER cluster is installed so the upper cluster bolts can be installed... makes the conversion a bit more difficult for cluster removal but why pull the cluster if everything's done and correct ?
edit-
to me, most important gauge is temp gauge. never never want to overheat, eyes are always on tach, speedo & temp
oil, fuel & volts are secondary
