I am really considering the Chassisworks frontend but have seen several post that said that they ran into issues if used a small block with 190 Air Flow Research heads. If so what headers did you use and what did you do?
Also, do any of you have a 700R4 transmission and how did that effect you?
Also, I am running a 4 wheel disk kit from ccp. Will I need to remove my current brake booster/ master cylinder with the chassisworks kit and if I do how will that effect my rear brakes?
Thanks Bruce
Thanks Bruce
