Wow, I thought I'd have a hundred responses by now, guess I have to do what people did before the internet... Find out on my own.:yes:
An astute observation. Quite often a driver will get the front to stick and next time out the rear will come around. Drive carefully till you know for sure.:yes:I have A Heidts and just changed from 450 to 400 and is a much better ride on the street. Now I may need to go lower on the rear
yeah i have 250 on the rear and its adjusted all the way soft and all though its better its not what i want. i talked to chuck church at the mini nats and he told me he had 175 180 in the rear so that may be where im headedAn astute observation. Quite often a driver will get the front to stick and next time out the rear will come around. Drive carefully till you know for sure.:yes:
I am curious what coil-over spring rates people are using in their Chassisworks front clips for street duty? I have a 67 with Chassisworks street machine clip and sway bar, 550 lb. coils on single adjustable shocks set on the middle setting and running a LS1... When I first ordered the clip I was going to run a small block but decided to go ls instead, I figure chassisworks recommended the 550 lb springs for the added weight of the sb. Now after putting a few hundred miles on the car with no change in ride quality I think it's too rough for the street and wanted to see what other people with experience with this are using.
I forgot what mine are. I'll take a look tonight and get back to you.
Dang, I took a look tonight, and I cannot find the numbers. I know they are on there and how they look because I see them on my rears. I'll have to dig back through my receipts and see which ones I ordered. All I can say is my car rides PERFECT. I wouldn't change a thing about the spring rates in front or rear (TCI 4 link with Varishocks)
I called the tech guy at chassisworks for a recommendation on the spring rate and he said guess what... 550 lbs! After I told him literally 3 times it rode rough he said drive it and if it rides rough go to maybe 450 lbs springs.I guess the go-to spring rate for all applications at chassisworks is 550 lbs. Maybe thats the best all around rate and I'm in the wrong just seems generally high to me.
