WARNING, WARNING, very long story.
I marked a spot on the harmonic balancer that should be 36* and got it timed (guess it is locked).
Shut the motor down and started to tidy things up in the engine bay and clipped a piece of tie strap off, and it just had to fall into the alternator
I could possibly get it with a tweezers as it was just sticking out a little, but nope, just pushed it all the way in :slap:
Took the alternator out, shook it, and shook it...... it just would not fall out. So I take the four bolts out to take it apart, and just when I split it, the piece falls out. Figures......anyway, put it back together and hear a snap
, maybe just binding a little? Anyways I put it back in.
Start the car back up and decide to take it for a spin around the block, first time since tearing it down to the short block, and first time this year
. I did notice the gen light was lightly glowing on and off. I go around the block and halfway around I decide to goose it a little and...... up comes the hood all the way!
Need to almost stick my head out to make sure it was safe to pull over and not sideswipe a parked car :bored:
The dip***** that I am, had forgotten to close the hood all the way before pulling out of the garage. :rotfl: Okay, get out and try and close it. Not going to happen, it pulled it out of alignment and is binding. Now I need to drive with it a third of the way up for half a block. Take it easy and made it home safe.
I leave the car running to see if she will get hot, had overheating problems last year when idling, but added an electric aux fan this spring and she held fine, so I shut it off.
Get the hood aligned again and go to start it again and a loud clank, pause, another clank. It would not start! :beat: I was hoping it was not hydro locked or something hit. Take all plugs out and they look kind of sooty, but not too bad, none are all that wet. Number one had a little oil on the threads though, but not on the rest. Never had hard starting problems before..
A while had passed while dinking around with it. Try to start it again and clank, clank, vroom...... it starts again!
Better get it in the garage :yes:
Park it, then shut it down and notice that the batteries negative terminal was smoking a little. Not good. I go to touch it and it was hot! I let it cool off and notice that there was a little anti-freeze near each of the terminals from when some spilled out off the radiator the day before. I clean it off then decided to sand off the spot where the battery was grounded to the motor as it was freshly painted and maybe the ground was not good. I then tapped the hole to make sure there was not too much paint in it to make a good contact.
Hmmm.... I wonder if it was running off of the battery and not the alternator and that is why the gen light was lightly glowing on and off. I did hear that snap when putting it back together.
I take the alternator out again and take it apart....again. Sure enough, I had broken a piece of one of the brushes off the first time. I go to fix the problem and can not figure out how to keep the brushes in when putting it back together.
I had noticed a neighbor a few houses down had one of his street rods out, why not ask if he knew the trick. This guy has a 40's buick convertible that he has fabricated so many things for. He put a mid 90's caprice frame, well the front and rear part of, the middle he made himself, under the car and put an LT1 in it. I could right a dozen paragraphs on what he had shown me, all I can say is the man has some INCREDIBLE talent! :yes:
Anyways, he told the the paperclip trick, go and put it back together after launching the springs a couple of times and lucky enough to find them. I go to start the car up to see if the gen light was off, and sure enough, that problem is solved.
Go to take a few more spins around the block with the wife and gas was real low, so better go get some. Do I take the risk of it not starting again? Sure, why not live life dangerously
I pull up to a very long stop line and was watching the temp, it looks fine, oh wait, huh? Climbed from around 190 all the way up to 220 in two seconds. Better turn around now! It then starts to drop as I start to move. I forgot to fill the cooling system all the way up, only about 3/5 full in the radiator and never did lift the front end up to try and get rid of air bubbles. Dummy....
Fill up with gas, go to start it, clank, clank, oh snip..... vroom.... Whew... Better head home. Get home and back into the garage, then shut it off.
I decided to try and start it, clank, clank..... nothing. Did I lock up the starter? Better let it cool off.
Hour later, tried it again. Nothing. Dash lights on, but no sound at all from the starter. No clicks, or anything.
Dang....... what did I do now.......
why do I have a muscle car again
opcorn:
edit: should this be in drivetrain, electrical, or 3rd gen, bs section?
Just need ideas as to what might have happened.
