I want to use it again with my new motor but don't recall if it just gets full manifold vacuum or timed with a temperature vacuum switch. Any help would be welcome, I hooked it up to full manifold vacuum and it seems OK, just wondering about it.
The reason I want to use it is because I think it keeps fumes down in the tank, plus it just looks that much more stockish and keeps me in good graces with the inspection guys.
1977 BTW
The 76 parts car I have is bone stock, I'll check it out this week end and see if I can trace all the hoses through the pack rat mess and also get you a photo. You may have to call and remind me, I am getting a little forgetful in my old age.
1974 Nova, 1977 Nova
Hi ALLT4,
The canister purge line is usually either Tee'd into the PCV vacuum hose or connected to a dedicated port on the carburetor. In either case it's manifold vacuum.
Too much canister purge flow can upset the air/fuel mixture though so various control methods are used and they vary by application. I think the 2-port canisters use some sort of restriction somewhere (probably in the carb's dedicated purge port) to limit flow. Some canisters have 1 or 2 valves on the top that control the purge flow. The small vacuum hoses that control those valve(s) usually go to a ported vacuum source on the carb.
I think I recall it being full manifold vacuum. I have it "T"ed into the PCV line right now and it seems to work OK, well lets just say I don't notice any difference in the way it runs.
Here's a pic, don't see any kind of valve just two lines one coming one going, the lower one in the pic is going to the PCV line... nice thing now is I no longer smell gas fumes in the garage, I used to shut it down and a half hour later with the doors closed smell gas something terrible.
