I'm not sure about the 67, but my 69 Quarter Window only took a couple minutes to remove once the rear seat and door panel were removed. There was a clip on the stud that is on the glass. Once you remove it, just slide it off the arm and the glass comes out the opening on the inner panelAnyone have any tips or time savers for changing the right rear quarter window on a 67 coupe?
that's all. no clips.Does the rear door panel on a 2 dr coupe have plastic plugs that hold it in place? Other than that is it just window crank and arm rest?
getting it back in is just as tedious. Just remember that the best way is to leave the regulater loose because you'll need to get the rollers lined up in the tracks first.Well after 3 1/2 hours of looking for an easy way,I got it out.Finally I just unbolted everything and dropped the track inside the panel,removed the felt and rubber trim peices at the top of window opening and it came out.I can hardly wait to put it back in !
