Has anybody got 5+ degrees of positive caster out of there stock 1st or 2nd gen Nova? I was at a car show today and a man told me , no problem geting 5+ degrees pos caster out of a stock suspension. He also said that his stock suspension is very stable at 110 MPH. Responses?
I had no problem getting +5° caster from my 67 stock front suspension.
One potential problem is the tire hitting the front of the wheel cutout on a 66-67. It's probably similar on a 62-65 but I don't have direct experience. I have a 25.3" tall front tire and it's close.
I would think the baseline caster angle should be around 5-7* positive caster. Caster angle is what makes the steering return to center.
All these fancy companies have led us to believe that only there stuff can get that 5+ caster in our cars. Oh well fooled me!
I had a lot of caster cranked into my sedan when it was a drag only car and trailered to the track. When I pulled it apart to put it on the street, I saw the lower control arms had been pulled so far forward they were rubbing on the frame U-brackets where the arm attaches. With open exhaust, I never heard it.
So yes, you can pull in the caster but it will put a lot of side load on the control arm bushing and possibly gouge up your control arms. I was going to put a shim or two between the upper control arm and the body at the front mounting bolt this time but got Church Boys upper arms instead.
In addition to the usual reasons for added caster I like that it adds steering input on a car with power steering.
PS in older cars has typically been a love-hate deal for me. I love it in a parking lot and hate it at highway speeds. Lots of caster helps quite a bit with the latter.
