1 - 3 of 3 Posts
I have noticed that the cast iron headed 6.0s have a lower compression ratio than the aluminum but both heads have the same cc combustion chamber. That makes think that the iron headed ones have more of a dish than the aluminum ones. Is this correct, I have been wondering this for a while now.
Casting Number 12562317 or 12572035
2001-2004 LQ4/LQ9 equipped truck
Material: Aluminimum
Combustion Chamber Volume: 71.06cc
Compression Ratio: 10:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve: 2.00 inches
Exhaust Valve: 1.55 inches
Part Number: 12572035
Casting Number 12561873
1999-2000 LQ4 equipped truck
Material: Cast Iron
Compression Ratio: 9.5:1
hope this helps a little
http://www.carcraft.com/projectbuild/116_0704_lq4_short_block/viewall.html
http://houstonperformancetrucks.com/showthread.php?12544-GM-Head-Casting-Info-with-flow-numbers
Casting Number 317, 035
Head: 2001+ LQ4 and LQ9 6.0 Liter Truck
Part Number:
12562317 -LQ4
12572317 -LQ9
12572035 -LQ9
Compression Ratio: 10:1 LQ9 Flat top pistons
Compression Ratio: 9.6:1 LQ4 Dish piston
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
1 - 3 of 3 Posts
