Well I kept having a problem with my car I couldn't explain or fix and it slowly got worst. I was having a steam/ oil problem out of my valve cover breathers but never could figure out what was wrong. Also i was also always being told my car should run better than it was. Well this weekend I took a vid of my car because it got worst and it showed the bubbling in the radiator that would say a bad head gasket.. So I took the top end off and found even more....Seems when I was building the engine I made a small error that turned big. It had been a few years since I built an engine and when I did my valve adjustment I did all of the them the correct way with exhaust close adjust intake and then intake open adjust exhaust. well on piston 2 I accidently did both of them when the vavles were open causing my intake rocker to come loose and fall off. Well I didn't no at the time but my piston must have kissed the valve...Hence the oil/steam that slowly got worst as I drove it....
So now I have to buy another piston and ring set, along with gaskets set...What fun always...
Here is a tell tale look at it....
