Another item ................ that I would check . . . . .
on each of u'r carbs - - where the fuel line goes into u'r carbs - - Look at the shape of those top covers .
Generally , where that connection is : there should be (could be) = a fuel filter inside that "round hump" . . . .
unless someone has removed them .
Be AWARE that if you check - for fuel filters in that spot - - - - - - - - - - - - "there IS a small gasket there & be
CAREFUL with that large NUT = do not 'cross-thread' that fitting (very easy too do) ............ AND ...................
Be careful NOT TOO Tighten that NUT TOOOOOOOO Tight . You can Crack the
carb houseing ; very easy ...............................
ask - Me , how I know ............... (been there & ruin a good carb , before) .
jim
jim
