I am installing P345/55R15 BFG Drag's into my 1st Gen and want the rear of the car to rest at stock ride height. The front 2" lower than stock.
Problem is, I lost the specs I recorded before I started cutting the car up.
I hope someone here might take the time to run out and measure their ground clearance for me. The distance between rocker box and ground directly in front of the rear wheel well opening would be a great help.
I found that I will need to stretch the stock wheel opening 2" forward and the inside rocker box area further forward than that.
I have a pair of wheel well opening patch panels from NNN that I can use to stretch the openings.
Anyway, these 30" tires are making me cut more and more out of this car. I have the axle so far up into the car, I have to raise the driveshaft tunnel.
I'll try to post a pic.
Thanks, Al.
Thanks, Al.
