I don't see a problem with that. I've got the same bracket and have a super victor with a one inch carb spacer. It doesn't get much taller than that.
Convert the car to manual linkage! ELIMINATE THAT CABLE!
so, can I use the spacers underneath the bracket no problem?
Mine sits on top of the nuts holding the carb down with another pair holding the braket down. I have no alignment issues with my Holley. What kind of carb are you running that is causing the alignment problems?
We have the same thing and we ended up moveing it up but it worked down low with the cable on a slight angle up and really seemed to be a better angle
as if it pulled back and down at full thottle as long as your cable mount on the carb pivots so theirs no bind.
