1 - 20 of 26 Posts
Stock rally wheels. Shouldn't be too hard to find them used somewhere.
wheels
they are around. Ebay, craigs or ask for them here on Steves
Had those on my 78 custom, got them for $50 off a camaro, they are 14x7 rally 2's, they also made them 14x6. Also 215 or 225/70 tire is perfect for those.
They are also sold thru the "aftermarket" system.
Coker has them, bare, for $88.00 each
http://store.coker.com/wheels/oe-style-wheels
My neighbor is running that wheel on his 39 Chevy and they lood good.
Those little chrome rings are expensive if bought new.
They only take one style hubcap, whereas the more traditional rally accepts several type caps.
Discussion Starter · #8 ·
Are the small 6 inserts interchangeable between 14 and 15 inch rims? Found a set for 14s but wanted 15 rims.
Those chrome inserts are hard to come by if not on the wheel. I think Paddock sells them for $6.00 but that ads up $6.00x24= $144.00 then add on shipping. Our Rallys inserts were gone but I found a screamin deal on ebay about 2 years ago and got em.
I gave two of them away with good tires. By the time you get the inserts, trim rings and center caps you can buy a really nice set of aluminum wheels that are lighter. Unless you're going going for a restored stock look I wouldn't bother. The center caps are the hardest find. Everything else can be purchased new.
Without the inserts they're pretty blah
1964 Nova SS
Are the inserts the same as was on the Olds rallys?
71-79 Rally Wheel Insert Bezels from Classic Industries.....23.95 each
$23.95 x 24= $574.80 :eek:
Don't forget shipping !!!
Discussion Starter · #16 ·
yea, I saw those for $24 each. what a rip off. I think they are worth tracking down though. I found a set, but they are for 14's....I dont mind using 14 rims, but wanted a little bigger. Not sure if they would fit the 15 " rims
When I retired from working in a Chevy parts department a few years ago, they were still in inventory, at about 2.50 each.
The chrome inserts were only used when the wheels were painted body color. The argent siver wheels did not get them. The early center caps are cast metal and the later ones are plastic. I had a set of the body color wheels with the inserts on a 78 El Camino. I wished I had removed them prior to selling the car.
1 - 20 of 26 Posts
