The 62 I bought has a very nice front clip(inner fenders). Comparing it to the 65 , the hood hinge front bolt holes on the 62 are closer together than on the 65.
Can I just drill and use spacers?
The 65 front clip seems to have a raised area for the front hood hing bolt holes.
62's have one year only hinges.....
but the clip will work.....
steering components are one year only also... pitman arm, think center link also.....
The mountings for the grill will be different but I suspect it could all be worked out. It will bolt up to the cowl with no problem.
Thanks for the replies guys:yes:
I would rather use the hinges off of my 65. The 62 hinges are worn bad and leave a lot to be desired. I assume the 62 and 65 hinges are the same spacing to bolt on the hood? I will dig one of my 65 hinges and compare
I will also have to drill the 62 hood for the 65 hood bar I guess.
I already had another clip to go on the car but the drivers side inner fender was warped during sand blasting:mad:
As far as the suspension goes I have the CPP lower kit and most of the Church Boys conversion.
Anyone know if the windshield from a 62 four door will work in a 65 two door post?
I can measure I guess but thought I would ask:D.
