1 - 20 of 52 Posts
Camshaft question What would be a good recommendation for Hyd camshaft for 350 -650 Holley-headers-4 spd- 3:73 rear?
I don't race , just street but want a real radical idle-sound. I have the Summit 1106- 292/488 but not quite good enough sound.
JR
Greetings,
Here's what I use for a radical sound (to say the least!)...Comp Cams 292H cam. It's 242 duration at 50 degrees and 501 lift. It sounds great at idle and while going down the road.
Jason
Get one of the factory vette solid lifter 350/365 or 350/375 cams. They have a ton of duration and overlap and sound pretty thumpy. If you actually want it to run right, however, you're gonna need 11:1 compression.
Why do you want a racecar sound without the racecar? This question would give Paul Wright a brain anuerism.
Kev
cause thats what he wants.;)
Kev
I want that mean cruizin sound. Too expensive to race.:D
get a cam with lots of duration and overlap....the car will likely be sluggish in the lower rpms and will come to life in the higher rpms.....BUT it will have a ratty idle:D
novaboy009 said:
BOOM!!!............ Yep, that was Paul's head exploding. How sad :(
Kev ;) :D
Not everybody has the same goals as Paul.....Paul lives in a world where getting every last bit of HP is the name of the game heck its more then just the name of the game it IS the game this is also a place where "form ALWAYS follows function"....most of us do not live in that world and that gives us the latitude to change the rules a bit, to suit what we want our cars to do, so that sometimes "function follows form". This is one of those cases.:)
But ya the ratty idle comment was for Paul;)
Think of positive side:) , you can run low octane gas with no problem becuase the DCR will be so low. Thats assuming your compression ratio now is around 9-1.
The other plus thing is you have a manual, so you don't have to worry about getting a bigger stall.
You don't need a lot of duration, just put the lobes close together. Crane has a few cams ground on 106° lobe centers that will give you the drive-thru idle, like the 282 H06. This will keep your cylinder pressure up and the cam won't be so lazy up until 3500 rpm. Note that it is set at 101°ILC. They're the H06 series on this page:
http://www.cranecams.com/index.php?show=browseParts&lvl=2&prt=5&Vehicle_Type=Auto&Cylinders=8&Engine_Make=CHEVROLET&Year=1969&Engine_Size=262-400%20C.I.
You should keep the exhaust system as a true dual setup with no crossover. Don't use much initial timing, this will make the idle poor. You can use a dual plane manifold and lean one side way out at idle, it will stumble on half the cylinders. Just don't put any of your timeslips in the window....
Yah, I'm well aware of all that. I was mostly pulling Paul's chain.
How much cruising will you be doing JR? Are you willing to run on hightest? What's your current compression ratio? What heads do you have?
I'd shoot for something with lower lift if it has stock heads. Most of them are all done by .450 lift anyway. You want all sorts of duration though, lots of advertised duration and plenty of .050 duration. Do you want solid lifters or hydrallics?
A GM 30/30 cam comes to mind as having a wonderful thump thump thump to it. The old factory cams are really outdated, so they ramp up nice and slow and need lots of duration/lift. Perfect for that ratty idle noise.
Kev
EDIT: Great idea on moving the lobes Mike. That'll keep it a lot more driveable and chop it up a good bit.
JR said:
Would you have a suggestion on the specs?
JR:)
JR, there are tons of cams that will do what you want. You should easily fiund one that will give ya the idle that your looking for. BTW as with all cams the "basic operating rpm" they are talking about is with the right valve springs etc etc, just installing the cam will not suddenly make a casr with stock or nearly stock springs be able to reve to 6000rpm+ And the springs are just the tip of the ice burg there are ather variables that will effect your ultimate rpm capacity. But anyway here are a few grinds that I am confident will give you the ratty idle you looking for. I've listed your current cam first followed by some cams from Crane...they are in no particular order and I personally have no preference...
Current cam:
summit cam
SUM-1106
Basic Operating RPM Range: 3,000-6,200 RPM
Duration at 050 inch Lift: 234 int./234 exh.
Advertised Duration: 292 int./292 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.488 int / 0.488 exh. lift
Lobe Separation (degrees): 114
Crane Cams grinds
grind number: H-244/3439-2S-6
Basic Operating RPM Range:3400-7000
Duration at 050 inch Lift: 244/252
Advertised Duration: 300/308
Valve Lift with Factory Rocker Arm Ratio:0.516 / 0.525 lift
Lobe Separation (degrees):106 (I believe..the crane site doesnt say)
grind number: H-238/3347-2S-6
Basic Operating RPM Range:3200-6800
Duration at 050 inch Lift: 238/244
Advertised Duration: 294/300
Valve Lift with Factory Rocker Arm Ratio:0.502 / 0.516 lift
H-308-2 (REPLACES CCH-308-2)
Basic Operating RPM Range:3400-7200
Duration at 050 inch Lift: 246/254
Advertised Duration: 308/316
Valve Lift with Factory Rocker Arm Ratio:0.495 / 0.510 lift
Lobe Separation (degrees):114 (I believe..the crane site doesnt say)
BTW remember to use any cam with increased lift will requre that you verify you have enough clearance....also changing lobe centers will effect your available clearace even if the cam have the same lift. Normally speaking the tigher the lobe centers the wilder the idle will be, the less vaccum created and the wider the power band will be. The wider the lobe centers the smoother the idle, the more vaccum created, and the narrower the power band will be....just some thoughts for you...Good luck:)
Mike Goble said:
You don't need a lot of duration, just put the lobes close together. ...
Very good point....much better idea than cranking the duration......the crane saturday night special series of cams are ground on the 106 lobe center.....
Jr, here are two from crane with a 106 degree lobe center that might just be the ticket for ya:)
part number 110592
@.050 duration: 228/234
advertised duration:284/290
lift .480/.494
rpm range: 2800-6400
part number 110182
@.050 duration: 230/230
advertised duration:286/286
lift .465/.465
rpm range: 3000-6400
I sorta like the first one:cool::)
One last thing JR, even though the lift and duration of these two cams are very similar to what you are currently running I would make sure you have enough clearance for this cam as changing to a cam with tighter lobe centers can effect piston to valve clearance in a negative way:)
Mike goble hit it on the nose , in fact he is the only one !! DONT USE ALOT OF DURATION!! , Keep it below 230 @.050 and find the tightest lobecenter you can .I would try calling around to cam companies and find one with a 104-106 LC. With this profile you will still have decent manors and a nasty choppy idle!!
crane does sell a few grinds, and isky sells a bunch also. stay around 480-490 lift.
Yep just like the last two I listed with 106 lobe centers...Now since his current cam has over 230 degrees of duration I didnt think it would matter to JR, since he is used to his current cam with 234 degrees, to have cams with duration in the 230 range......I like crane but that is just me....sorta a personal preference is all I'm sure just about any cam maker will have a cam that would work well for what JR wants. :)
Discussion Starter #20
Thanks, I will start looking for a new one. Really all I want is for the engine to sound real mean like -Ya better not mess with that ole Black primered Nova.:D
I ain't real worried about RPM range. Just gonna be a cruiser every once in a while.:)
Thanks for all the info. I don't really understand cams that much, but ima learning:D
1 - 20 of 52 Posts
