I have a camshaft in a motor that I am trying to identify. It is stamped Z087 on the end and has a couple of other markings on it, CWC and EP1. I have googled and found nothing. Is there a site out there which will help identify this cam?
cale
We had another thread that had "Z025" on it. We struck out trying to identify it.
If you can find someone with a "Cam Doctor", they can measure the cam and print out it's specs. You could do the same thing manually with V blocks, dial indicator and a degree wheel.
I'll post it on another sight which has a few cam designers and grinders on it frequently. We'll see if it gets any hits.
thanks for the info so far. If I cant find it anywhere I will dial and degree it but had hoped to find the identifier somewhere.
Hopefully something will turn up somewhere.
cale
Got this info for ya. Hope it helps. If I get any more I'll post them as well.:yes:
"CWC" is the foundry that cast the core.
"EP1" is a small block chevy flat tappet core made by EPC
I don't know what the Z087 is.
If it's "2087", it could be one of mine.
I only stamp the invoice numbers on the back of the cam, and 2087 was a flat tappet SBC.
_________________
Mike Jones
Jones Cam Designs
Denver, NC
www.jonescams.com
(704)489-2449
You need to run the correct lifter against the cam in this type of test stand. If you were to run the tip of a dial indicator the durations will come out way small vs. a flat or roller follower.
As far as the Z087 number, I would guess its an Elgin industries E-1087-P. Measure the lobe lift with some calipers, it should be .295" on both intake and exhaust lobes.
1087 specs, 280/280 adv. 214/214 @.050" .443"/.443" Valve lift and 106-114 centers, 110 LSA.
