Raymond, FWIW.... I have the lock outs on my 66. The springs are original and the stock front end rebuild is approx 4 years old. With the drum brakes my camber setting was on position 5 (as viewed from the front). This gave me approx .5 deg of camber (with 2 deg of caster) Remember, caster affects camber and camber affects toe so its all inter-related. Now, that being said, with my disc brake setup it appears that 6 will be the new setting as this disc setup needs all the camber adjustment I can give it just to make it driveable. Its a sometimes maddening process.
