:eek: O.K., I bought a Pete Jackson timing gear set on ebay. It is new, but only had some of the intructions with it. Now I know how to install it, but dont know about the cam timing. It came with about 5 cam buttons that I am sure are different degrees. How can I find out which is which, and any advice on what degree to use if any? I think I am asking this the right way, so sorry if I messed up.:eek:
How about a little info on your engine so we can better answer your question,What cam,heads,rocker arm,compression etc etc...... does your engine have.
Sorry. It is a 454 bored 30 over.
TRW forged pistons with around 8 1/2 to 1 compression
Forged GM crank
Forged Scat Rods
Crane Powermax # 134561 (Hydraulic)
Lift .553"/.571"
Duration 296 / 306
RPM Range 3000 - 6600
Iron Heads with port work and 2.25 / 1.90 valves
Dart single plane intake
It will have a D1SC Procharger set up with a 850 DP Holley and 12#'s of Boost
I hope that is enough info.
I had to put a motor together a couple months ago with a Milodon gear drive and had no idea how it went together since it came in a basket. I went to their web site and found printable instructions there for theirs. I had a PJ gear drive years ago and I hated it because of the backlash. This Milodon was actually a pretty decent unit with no backlash like the PJ had. See if PJ has a site with instructions? JMHO, RM
The offset bushings usually come in 0,1,3,5,7 or 0,2,4,6,8 degrees of advance, with the highest offset being the most eccentric.
The cam you chose comes with 5° of advance ground in, so you'll probably use the zero degree bushing with the centered hole.
Perfect. Thank you very much Mike.:D
I agree, use the 0 key. I have played with cam timing and can say I never realized any track tested difference from 4 retart to 4 adv. I think the reason is there is a slight benefit to moving adv or retard, you basically shift things slightly, retard will give you a slightly higher pk HP, when I say slight I mean 2-3Hp on a 400hp motor, but will slightly reduce you mid range. So any pk gain will probably be offset by a mid range loss. Just my theory/thoughts.
After spending countless hours playing with this I install my cams "straight up", only verifying that what I have is consistant with the manufactuer specs.
Actually what this does is changes the valve opening and closeing cycle.Which builds up more cylinder pressure when advanced, And bleeds off some when retarded.
