Need help choosing a new cam.
I want brute low end torque and a noticeable idle.
Here are the specs of my old camshaft I used-
Basic Operating RPM Range 2,200-5,200
Duration at 050 inch Lift 218 int./218 exh.
Advertised Duration 274 int./274 exh.
Valve Lift with Factory Rocker Arm Ratio 0.450 int./0.450 exh. lift
Lobe Separation (degrees) 106
I'm guessing it sounded really good due to the lobe separation being such a low degree. I want a camshaft that will work with stock valve springs. My old camshaft was ok but the RPM range was a little on the high side. This will be a daily driver and I'm going for street performance.
I've been looking around and found two cams that I'm interested in.
Howard 1
Howard 2
I'm open to other suggestions.
Howard 1
Howard 2
