when i install my gears and my posi will i need to calibrate my speedo? if so how do i do this
gfercaks33 · Registered Joined Jul 7, 2007 · 2,585 Posts Discussion Starter · #1 · Mar 23, 2009 Only show this user when i install my gears and my posi will i need to calibrate my speedo? if so how do i do this
Lugnut79 · Registered Joined Feb 17, 2009 · 1,669 Posts #2 · Mar 23, 2009 Only show this user Chances are good you will have to if they aren't the same ratio as you took out. Check out this website. It will tell you everything you need to know http://www.novaresource.org/speedo.htm
DANNO · Premium Member Joined Feb 6, 2004 · 4,492 Posts #3 · Mar 23, 2009 Only show this user Here's some info: http://www.transmissioncenter.net/speedometer_calibration_______va.htm http://www.tciauto.com/Products/TechInfo/speedo_gears.asp
gfercaks33 · Registered Joined Jul 7, 2007 · 2,585 Posts Discussion Starter · #4 · Mar 23, 2009 Only show this user im going from like 3.08 to 4.11
Lugnut79 · Registered Joined Feb 17, 2009 · 1,669 Posts #5 · Mar 23, 2009 Only show this user That Nova Resoures link is great. I followed the charts on it and got my friends 69 camaro Speedo within 2 MPH of my GPS.
tnblkc230wz · Premium Member Joined Dec 13, 2006 · 4,373 Posts #6 · Mar 23, 2009 Only show this user You can call the www.gearbox.org. Tell them what you have and they will tell you what you need. The plastic gears are about $11 each.
