1 - 3 of 3 Posts
i need a direct fit after market steering column/harness for my 66. the horn shorted out and burnt up the whole column.
is there an aftermarket col, that will directly fit? i have all stock steering and floor shift. i dont care about tilt. i still have the original steering box with the straight shaft from the box to the wheel
I just got a new turn signal switch and harness for my 72 from my local parts store. Fit fine and was only $55.00. The plastic part the arm screws to was cracked on mine. I was surprized that they are available so you may want to check your local parts stores for one. RM
the switch was no problem, got it... there was nothing to bolt it to cuz the column burnt up!!! all the little peicess are gone and i dont know where to start. so ive decided just to get an aftermarket column
1 - 3 of 3 Posts
